Any parametric updates?
9363.56 In reply to 9363.54
Hi Michel,
> To avoid possible confusion with visible lines when printing screenshots in black & white, do you
> think you'll be able to insert a small gap between dimension elements (extension lines, arrows)
> and objects?
So something like this for the extension lines? :
For the gap on arrows, would that also apply to the arrows going to the extension lines in a linear dimension like above, or only to the arrows on other dimension types?
I'm not sure if I'll be able to do an arrow gap on angular dimensions because that would also involve trimming back some of the arc that is being drawn, but I could do it for radial and leader dimension types.
