Hi Pozero - there currently isn't any way to do this from MoI, but I do want to add some tools for version 2.0 that would make this kind of organization possible.
For now each object in MoI is exported as one object in the OBJ file.
One way you could get what you want is to use Edit/Separate to break your one large object up into individual surfaces. After that each surface will be it own individual object and should export as different objects in the OBJ file. But this will also have some bad side effects of possibly making some slight cracking in the edges between the different objects.
Normally a polygon mesh modeling program will have various editing tools that can be used to break a mesh apart into different pieces. I guess that Poser doesn't seem to have these kinds of mesh breaking tools.
