Curve projection question
9335.2 In reply to 9335.1
Hi Elliot, when you extrude a curve you'll only get a solid result with capped ends if your curve is closed and planar.
But if you extrude a surface you'll be able to get end caps in the situation you're describing. So the usual method would be to trim the surface with your curve as a cutting object, and Trim actually has projection built into it so you don't need to project as a separate step. Then when you have your surface fragment you can extrude that into a solid.
Check out here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=4010.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=3318.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
Hope that helps! - Michael
