Operation question
@Mark - the middle mouse button click sounds like a better idea since it would be fewer steps. I'd like to experiment with that after v4 is wrapped up.
@nameless - if you want to have some predefined extrusion distances, that is possible in the current v4 beta using the newest UI control mechanism. Set up a keyboard shortcut like this:
extrude distanceinput=10
Then when you trigger that shortcut key, it will run the extrude command and set the distance input field to 10 which will finish the command. So set up several shortcut keys with different distances for the kind of thing you're describing.
