Objects unpaintable in Substance Painter
9309.16 In reply to 9309.15
Hi Jack,
> It seems however, that Moi only exports the selected colors and the names given to the materials do
> NOT "stick" to the material selection/definition. When I export in OBJ format some apps, like Armorpaint
> and SP get the materials (colors) right, but assign the names incorrectly. The windows for example
> become object1 and object 3, the door object2 and the wall was correctly named.
There is more than one kind of name label involved, it sounds like you might be getting the different labels kind of confused.
When you export to an .obj file the style assignments in MoI will become material assignments in the .obj file and the styles list will become the materials list.
Separate from materials there is also in many programs a concept of an "object name". You can set this in MoI on an object and it is a separate name from the style assignment and style names.
If your object in MoI was not assigned an object name, MoI will make a generic one like "object 1", "object 2", etc... for the object name property in the exported .obj file.
If you don't want to see those generic names then you would need to assign your own object name inside of MoI. You can assign a name to an object using the properties panel, click on the name line and an "Edit name" dialog will come up. Again, this is separate from the style assignments and style names.
