computer performance
9303.4 In reply to 9303.3
Hi Mr. Yuri, I don't have any particular preferred transfer service, anything (Dropbox, One Drive, etc...) will do.
But if you have 400MB of size all in just one single object, the very high complexity of that one object is probably going to be the cause.
Some things you could try would be to enable the "Keep separate" option in the Extrude command which will stop it from automatically doing a boolean calculation automatically:
Or also if you duplicate the edges around your desired extrusion and extrude those instead of the object face. That will likely improve things because then it won't be sending a large amount of data over to the worker process and back again.
