Match Properties
9298.5 In reply to 9298.4
Hi Marc, you're welcome!
> I've noticed the order of selection is inverted compared to the usual "copy formatting"
> paintbrush but I have no problem with that !
That's so it will be consistent with the "noun, verb" sequenced used by other MoI commands. When something modifies objects, the normal sequence in MoI is to select the object that will be modified first, then do additional input after that.
