| Oops, one other thing:
 > I opened up the working rhino file in MOI and again I got nothing, just a plane.
 That's actually normal for right now - MoI does not currently read the texture mapping information from Rhino objects.
 You probably used the "PictureFrame" command in Rhino? That basically creates a plane object and assigns a texture map to it.
 Since MoI doesn't read the texture map information, you will just see the original plane object when you import it into MoI.
