Hi Flippy,
I recreated the outer surface by copying the circle and the outline at the bottom and then using loft to connect the shapes. Then replaced your outer surface and joined to a new solid. It fillets now, at least here.
My guess is that the bottom outline was too fragmented. My original thought was to use a merge script to create a more continuous line, but it didn't work so I went ahead with the above solution.
I left the lines I used to create the loft so you can see.
ps. sometimes it seems like you have selected a whole loop to fillet, but there is a small unselected section that creates a problem. Scripts like this are handy for selecting loops fast (even if you have to deselect some parts after running the script):
script: /* Loop selection */ moi.geometryDatabase.selectLoop();
Select at least two consequent lines and it will find everything in the loop.
