OBJ Importer Plugin - how to install - how to use?
9273.4 In reply to 9273.2
Hi Lara (MALA)
The third method to run an add-on script is with the "external scripts" icon button, (two meshing gears), at the bottom of the MoI screen.
This requires Max's CustomUI to be installed, and also that the desired script be copied to MoI3's command folder.
(Max's convention of preceding every add-on command with _ was for myself to keep track of them, versus stock commands.)
A very useful feature of MoI4Beta is that the add-on script can be copied instead to a different folder.
This permits using the "stock" MoI4Beta commands folder for standard commands, and entering add-on scripts in the separate folder.
Then upgrading to a new MoI4Beta, is super easy. All of the "extras" are available, and do not need a re-install. (add-on scripts, customUI, nodeeditor, lighting, etc.)
For Windows the secondary folder is located in the %AppData% path.
For Mac the secondary folder is located:
"... - it's in the user Library: ~/Library/Application Support/Moi or /Users/[your user name]/Library/Application Support/Moi , not the system one."
(http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.779)
Hopefully this information is accurate :-)
