Thanks so much for the script. However...I'm having 2 issues.
1. If I select the organic curved surface (non-rebuilt surface)...I get the planar boundary rectangle, which is quite a bit larger than the Rhino Create UV curves boundary rectangle.
2. I do not get the edges curves of the curved surface with the boundary curves.
Now I also have a surface that is "rebuilt". The "rebuilt" version...nothing happens, no curves at all.
Tried to select the edge curves then use the script...nothing happens either.
So I can get the planar boundary curve rectangle...but not the planar edge curves of the surface object which would be inside the planar rectangular boundary curves.
Any idea?
M
