V4 beta Feb-27-2019 available now
9266.143 In reply to 9266.142
Hi Michel, thanks for the v4 feedback!
> PDF export crash report
> Mac Beta version crashes on my side when exporting a rectangle to pdf.
> I tried on OSX 10.9.5 and on another machine on 10.12.6 and both crash.
Was a crash report file generated? That would be under ~/Library/Logs/DiagnosticReports/
If one was generated could you please send it to me at moi@moi3d.com or post here?
One thing that you might check though is your setting for "Canvas megapixel resolution" in the PDF export options dialog when generating a hidden-line drawing. If that is set to a particularly large value but you do not have a corresponding very large amount of system memory then that could result in a crash currently. Since MoI v4 is 64-bit now the limit of how much memory it will try to consume has also been increased, that could be why you see a difference in behavior here between v3 and v4.
It takes up about 34 MB per megapixel and putting it at something like 1000 will consume about 34 GB.
> 3D view rotation speed observations
> Also, I find that in 3D view space rotation and zoom in/out seem slower in v4 ("bumpy"?) when the grid is visible.
> Much smoother when grid is masked or when using Parallel (isometric) view.
> However, in Parallel view, display artefacts are more apparent.
What is your setting under Options > Grid > "Grid sections" ? The default is 150 but if you have changed that to put in a high value there that might cause these kinds of problems.
