Freeform Intersection? How?
9263.3 In reply to 9263.2
Ok, so first, it didn't even occur to me to click on Through Points, which is RIGHT THERE, so thank you for that.
I went down the rabbit hole though, and the Rhino HBar style command is what I was looking for. Except with construction lines. Is there a way to turn on construction lines while in point mode?
I managed to get the general shape I want by splitting it into segments.
I will try using Through Points on V2 and see how that works. I'm guessing much better. :)
Another question - On a shape like this, how do I maintain continuity of the entire surface? For example, I see a lot of Surfaces coming to points as they reach a control line. You can see that on the handle in the attached image.
