Shrink+Join+Expand Script Question
9250.2 In reply to 9250.1
Hi Cody, when it is time to select the origin point for the scale, just type 0 and push enter. That will use 0,0,0 as the origin point. Then when scaling back up again do the same thing and your object will be back at its starting size again.
You can do the whole thing through typed operations, type Tab which puts focus in the XYZ input box, then type scale and push enter which runs the scale command, then type 0 and push enter to use 0,0,0 as the scale origin, then type your scale factor like 0.01 and push Enter.
