Hi Axel,
> Do you have plans to implement such feature as it is in Rhino?
Not currently - it was actually one of the earliest design goals for MoI to avoid doing the same as Rhino since the Rhino way pops that up so often and it's an "in your face" type of interruption.
So instead of doing something after you click, MoI is set up to do pretty much the opposite and give you feedback before you click by the "halo" type highlighting.
But it could be possible to add it in the future though as an optional thing like maybe using Alt could do that.
The main way to deal with things getting in your way though is to hide the thing that's interfering so you can more clearly see what you want to target. Or as mentioned above strategic use of window selection (starting from left going towards the right) that only targets things completely contained in the window can work too.
If you have a situation where none of that helps, if you could please post the .3dm model file for it that would help me to either give advice or figure out what new tool would be good for that.
