Line / Curve selection
9249.4 In reply to 9249.3
With MoI, I've learned to model in color groups so I can hide and show components. I use certain colors as just guide lines, for example. I occasionally name objects together (works just like grouping) that I know I might want to select in a single click later on and do this before I model more around it. Also, hiding all solids temporarily to see just the curves, etc. However, I model jewellery and I imagine it's not nearly as complex as other modelling endeavors.
With your comment about selecting a short line on top of a long line, that's where I'd draw a selection box around the short line that highlights everything inside the box only. However, I believe I've noticed a pattern with how things are "layered" in that things that are created or pasted last have priority when the cursor highlights them. Try this, take two lines that overlap (but one being shorter and "inside" the other). If you select the longer line, then cut and paste it, it will receive all the mouse highlighting. Draw a box around the shorter line (using the method I described) and cut and paste just that shorter line. You'll notice that the mouse cursor highlights the shorter line as priority.
So what I've done (while I'm modelling) is with any short overlapping lines, I select them, cut and paste them as I go. This way, I can always quickly select the shorter line with ease. I also make sure they are a different color so I can see them with ease. The last object created or pasted also receives the priority of the pixels being draw on the screen, I think.
Ideally though, it would be nice to hold down a key while clicking, and then a list of all objects that are directly under the cursor appears (they'd all just say "curve", "curve", "solid", etc.) and as you mouseover each listed item, it highlights them in the live 3D view so you know which curve is the curve you want.
I hope that helps you make better headway with your modelling, Axel.
-- Cody
