Hello Michael,
I know from Rhino a good feature where a small window opens once you hover over objects (lines, curves e.g.) to select the appropriate part you want to select. Such feature I miss in MOI. Often it is hard to select a shorter line which is covered by a longer line and only by coincidence it seems the shorter is highlighted for selection. The longer line gets the priority in that case. I know that you can start a selection field and draw the field as ling as you get the line highlighted that you want to select. But this method does not always work depending on the whole object sometimes obstructing the area where the line for selection lies in.
Do you have plans to implement such feature as it is in Rhino?
If I miss here something relevant that solves the issue anyway, please let me know.
Best regards,
Axel
