Blend Command V4
9222.5 In reply to 9222.4
Hi FED, do you mean this one here? :
To make that blend you'll need to delete the original circle curves, delete the end caps, then select the 2 edges and run the Construct > Blend command, here is an example video of the entire sequence:
Hope this helps!
