Modelling questions
9216.58 In reply to 9216.57
Hi Bravlin, it's usually best to do such edits on your unbent shape and then do a new Flow with your updated object.
It is possible though to do a kind of "scale from center path" operation with Flow, to do that you would make a Sweep of a line profile:
Along a central rail curve:
That will be the base surface for the flow. Then make a narrower sweep surface using a shorter line along the same rail, that will be the target surface for the Flow. An example result is attached.
