Modelling questions
9216.41 In reply to 9216.40
Hi Bravlin,
> I can't understand what exactly cause the problem with this shape.
Well a few different things - too much variation in shaping between stations, like you have tight bends in the corners and then those collapse down to a pole point for the next station. There shouldn't be so much variation between profiles.
When collapsing down to a pole it's best for the shape to resemble a circle before the pole, something more like the attached file. But overall it's not a feasible shape to try and do with one single surface with poles.
Little skinny pieces are because of sharp corners not being aligned to the other direction's curves:
> The result shape on a picture is a combination of extrude, trim and loft.
> But if you look on it, shape lack of continuity and smoothness on edges.
Can you post the model file so I can get a better look at it?
> But for more square like shapes that also have smooth edges and tilt (so they not easy to
> trim or extrude) i still don't know what to do.
You build an extrusion that is straight and has flat ends initially, then introduce tilt by cutting it with a side profile, something like:
