Sweep between 2 curves - use only a portion of those curves
9175.1
a feature that would be killer: a way to sweep between 2 curves (or more) but instead of using the full lenght of the curves, you could manually click some limits. It is especially usefull when you are sweeping between 2 curves that have very different lenght (e.g. one is very short and the other one super long, you would like the surface to have the lenght of the smaller curve)
Here's my actual scenario (see attached picture): i built a quick and rough wireframe vehicle - made with curves. I would now like to create some quick surfaces in between those curves but for this workflow to work, I need to use only portions of each curves, otherwise I would have to control the lenght of each curves or build some cross sections
It's a workflow I use in Catia and it might be possible to implement in MOI. In some ways, it's a bit similar to the points you drag after doing a blend surface - to adjust the alignment of the cv's.
If my explanations are not clear enough I can explain with step by step example images.
Best regards
Size: 208.3 KB, Downloaded: 74 times, Dimensions: 1368x777px
