what is best solution for export .obj?
For my projects I export poly in STL files for 3D printing with objects which are up to 3 cm.
My export options are :
Angle : 3
Divide larger : 1 / all
Avoid smaller than : 0.3
It's a pretty good choice to have details and not so big files.
You have to make choices size vs details.
But it depends of your using of files... rendering, 3dprinting...
You have to see utility of details in your work.
Render far objects with multiple details is not a good idea. But if you zoom in, using a more detailed file become a must.
So test ! Test ! Test again...
