Network Command
9148.7 In reply to 9148.6
Hi FED, it helps a lot if you can please post the .3dm model file with the curves in it instead of only a screenshot.
That way I can do things like examine where the endpoints of your curves are and zoom around and inspect it from various angles and other stuff like that which isn't possible to do with a screenshot.
From your screenshot my best guess is that it looks like some of the curves in one direction are closed and some are open - all of the curves in one of the network directions should be the same with regard to open or closed, not a mix.
Thanks, - Michael
