Network Command
9148.3 In reply to 9148.1
Hi FED, the Network command doesn't really depend on the video card. But it does need the curves to be in a particular kind of arrangement, there has to be 2 sets of curves that cross over each other in a type of 2D grid pattern. If it can not find that type of 2D grid pattern Network won't be able to make a surface.
If you are having a problem with some curves not working as expected, please post a .3dm model file that contains the curves, that will make it possible to give you some better feedback on why it is not working.
