Save custom UI?
9121.5 In reply to 9121.4
Ah ha...got the Custom tool bar working. But a few issues...
1. "Object Library"...the stock objects (cube, sphere, surface) are not showing under that button in Moi V4. I tried to move the "Objects" into Startup but that didn't seem to make a difference.
2. "Scripts"...I see 2 scripts buttons...I put a few in the "Scripts" V4 "commands" folder from the Application Support/Moi/commands. Nothing showing in either "scripts" folder.
3. "Lighting" button...tried to copy in the LightingOptions.htm I use in V3...nothing showing under that button in V4.
4. It seems the Tool Bar menu name change trick does not work to make an option not visible on V4. I had to remove the option from the AppSup/Moi/Startup folder to get it off the tool bar. For example "26 HideLock" is visible but "-26 HideLock" is also still visible...in V3 with a name change it would not visible in the bottom tool bar.
I noticed that under the V4 "Commands" folder under "Show Package Contents", all of the scripts I've been using in V3 show up in that folder...but are not visible from the V4 "Scripts" tool bar buttons.
...and I noticed all my hotkeys from V3...are somehow in V4 without my putting them in there...which is great!
Also tried to restart the computer to see if that would fix some of these issues, no difference.
Screen shots attached of what I'm seeing under V3/V4 "Show Package Contents"/drive_c...vs what's in the App Support/Moi folders
Thx!
M
Size: 71.4 KB, Downloaded: 42 times, Dimensions: 282x668px
Size: 321.5 KB, Downloaded: 37 times, Dimensions: 828x766px
