Is it possible to configure straight snap to only snap to surface normals?
9113.4 In reply to 9113.3
Yes! But one by one! :) Maybe there is a Plugin By Max Smirnov! ;)
(i come back in 5 minutes) Edit Yes it's Dispersion ! http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
else for the one by one...
That is for that the Function Orient / Line-Line is made! ;) (my favorite function :)
The Helper Line "Normal" give you the Normal of the Point on the surface for draw your object! ;)
Here the normal point is the "White bottom Point" ! (not the black cross : it's just hasard that it was aligned)
You can have Uniform, Stretch or No Resize Size's Cylinder ! & (Copy or not)
Normal is "Normale" because I use a French version of Moi! ;)
By Max Smirnov
EDITED: 28 Oct 2018 by PILOU
