Is it possible to configure straight snap to only snap to surface normals?
9113.1
When I'm placing cylinders (prongs) on a model using the Orient Line to Line command, I would like it if straight snap would only pick up the surface normal at a point, not the vectors parallel to x y and z. The other straight snap directions only get in the way. Is there a way to do this? Thanks in advance!
