Tube Intersection
9108.4 In reply to 9108.3
Hi Sharif, the shell command will have problems with thickening junctures like that. So instead of shell the process i used was: Select one single profile curve. Run Construct > Sweep, select the central path as the sweep rail. Turn off "Cap ends", then finish the sweep. Now the outer surface is created. Next sweep the inner curve in the same manner. Then select the inner and outer curves and use Construct > Planar to make the end cap surface. Now select all 4 pieces and use Edit > Join to make the solid that I attached above.
For merging in the other piece I'd probably use Edit > Trim to do that, I'll see about giving you some steps for that in a bit here.
