V4 beta Oct-17-2018 available now - SubD to NURBS conversion
9100.257 In reply to 9100.256
Hi Lordfox,
> Is it possible, to import an OBJ too but without SUB-D?!
Sorry, no not with any built in tools. An OBJ file without Sub-D is a faceted polygon mesh model and MoI is not designed to work with that kind of data for modeling. You would need to use a polygon mesh modeling program to import and work with that type of data, not MoI.
> Any possibility to set the strength of the build-in-SUBD?
Sorry, no not currently, it just uses the standard Catmull-Clark approach. At some point in the future I do want to add some edge weighting options but that would be unusual to do that directly in the OBJ importer.
> And for some OBJ Objects I dont want have SUBD ... e.g. if I import a pose from DesignDoll - nice tool
> for posing, but the poly-mesh-structure is very weird, lot of tris and so on - SUBD will not work well or
> much too long.
That model data is just not suitable for use in MoI in general - it's not what MoI is focused on working with.
