V4 beta Oct-17-2018 available now - SubD to NURBS conversion
9100.221 In reply to 9100.220
Hi nameless, I'm glad you got it solved!
> Is there any drawback in adding extra commands and scripts in commands folder?
> MoI launches lightning fast since day 1 anyway.
The main issue is that later on when you get a new beta version installed you will then need to copy them over into the new one as well.
In v4 this can be avoided though since MoI v4 will also look in the appdata/commands folder instead of only in the installation folder one.
The appdata folder is the same place where moi.ini is located, you can find that location by going to Options > General > "Edit .ini file" button - that will open up a dialog and it will show you the location of the appdata folder.
If you copy your extra command files into that commands folder, that's then separate from the application install location.
