V4 beta Oct-17-2018 available now - SubD to NURBS conversion
9100.151 In reply to 9100.150
Hi Alex, maybe check the advanced properties of the "High performance" power plan. Maybe it still has some CPU throttling set on it. If not I guess it is just getting too hot with all CPU cores running and throttling anyway. I'll make a setting in the next v4 beta where you can limit the number of CPU cores used for file loading maybe using just 2 or 3 cores on that particular machine will work better if it just can't thermally handle all at once.
