Export Points from object into txt file
9071.7 In reply to 9071.6
Hi dune1982, for that case select your main curve and all the lines that cross it and use the Construct > Curve > Isect command to intersect them. That will generate a point object at each intersection and you can then select all points either with a strategically placed selection window or by using the Types > Points entry in the Scene Browser, then export them.
