Hello ! Absolutely, here is more context :
https://www.youtube.com/watch?v=4Mtun8PgbfQ
On this example I am working with a bunch of curve objects (a total of 10) that will be exported to points data using SavePointFile as per the topic of this thread. It is a trivial thing to do when dealing with only a single curve object, but the selection process becomes quite tedious when working with multiple - as one often ends up selecting full curves, which in turn leads to a selection buffer than does not get converted to standalone points. You'll see me fight against that in the clip.
So from there I was wondering if there was any way to automate this conversion process - that is to say, running some sort of "extract points" command, operating on multiple objects at once.
(CurveArray can be a good workaround at times but in my case here it is not practical as the curve objects are already optimized and are crafted with as few points as possible).
I hope this makes more sense !
