Export Points from object into txt file
9071.24 In reply to 9071.23
Hi pior,
> So perhaps it could be possible to write out a structure that does both ?
Currently there isn't any way to adjust the line endings in MoI's text file output to MS-DOS style but it would not be hard to add in an option for that in the future once v5 betas are underway. For now to get that you would need to open and resave it in a text editor that allows you to control the line endings.
> On a related topic : is there a feature in MOI that would convert shapes (with lines, polylines and curves)
> to segmented shapes, similarly to what the DXF exporter does to shapes and the OBJ exporter does to
> filled shapes ?
You could use the DXF exporter for this purpose, save out to DXF format, with Export type = "3D Curves", and Write curves as "Polylines". Then read the DXF file back into MoI. That should convert curves into segmented lines.
