Export Points from object into txt file
9071.20 In reply to 9071.19
Hi pior,
> It is giving me a long series of floats, separated by commas. I suppose that they are to be interpreted as X0,Y0,X1,Y1,X2,Y2... and so on ?
It should be making a separate line in the text file for every point with an x,y,z value on every line.
Can you please post an example output file where it's all on one line?
Are you using the version from here? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=5124.2
> I suppose the order is maintained from the original object ?
It's going to be in the same order that the point objects are in the geometry database.
