Export Points from object into txt file
9071.18 In reply to 9071.15
Hi dune1982, it looks like the error report is off, the actual error is 2 lines down from GetObjects(), here:
linelist.addObject(objectpicker);
ObjectList.addObject() expects a geomobject while that is passing an objectpicker instead. Also further down for the setInput call I think you need to pass just linelist since it is an objectlist, linelist.objects would be an error.
So something like this:
//Will do the intersection
function DoIntersect()
	var objectpicker = moi.ui.createObjectPicker();
	//objectpicker.min = 2;
	if ( !GetObjects( objectpicker ) )
	    return;
	var picked_objects = objectpicker.objects;
	for ( var i = 0; i < picked_objects.length; ++i )
	    linelist.addObject( picked_objects.item(i) );
	var factory = moi.command.createFactory( 'intersect' );
	factory.setInput( 0, linelist );
	factory.commit();
DoIntersect();
