Export Points from object into txt file
9071.11 In reply to 9071.7
Thank you Michael, the isect command works just fine.
Ok now I have to make a script that will creates trose 500 hundret lines with a distance based on the length of the initial curve. Then automaticaly select the curves and run the isect command. Then export the stuff to a file.
Sounds like it is possible but I nearly lost all my scripting skills over the years.
