Export Points from object into txt file
9071.1
Hello MoI Forum,
I wonder if it is possible with MoI (perhaps with a script) to set points on a curve and then extract those coordinates into a .txt file.
For example think of a freeform curve that is over all 100mm long (if you walk along the curve), now set a point every 10mm of the way. Export all coordinates of the points into a .txt file.
