The more simple :
draw your 4 th curve like this you will see exactly where drawing it / existing surface
kill the previous surface lofted
Select the 4 curves
call Loft
Careful : if you select the 4 curves one by one : order is important!
If you select them by box selection normally you will obtain a progressive surface
