Offset + Rebuild as polyline interactively
9066.7 In reply to 9066.6
I'll add the closed curved functionality and post back the script here, thanks.
Regarding the point on polyline behavior, what I meant is that the picker does not let you place an actual point to be used as the starting point as well as the offset value. Currently, only the offset value is read, not the location of the point where it was clicked. If that would be possible, one could 'slide' along the original curve, and determine the place where the points are being distributed from. I'm not sure if that complicates things a lot, though.
I'll see if I can do some polygon reduction work as well ... thank you for the hints.
- Fabien
