Brachistochrone Problem
9065.5 In reply to 9065.1
Hi yakas,
Based upon reading numerous papers, which include lots of calculus, the problem needs to be defined. What are the coordinates of the start point A,
and the end point B? Can we assume zero friction?
Without friction, the Brachistochrone curve is a cycloid. (There are more complex equations in the case of friction.)
The problem is determining what radius of cycloid fits the start point A, and the end point B, if they are not level. This requires a "solver" program.
This link shows a cycloid, and simple solution by Gary Brookfield, for the case that A and B are level, and separated by horizontal length L:
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.509.2999&rep=rep1&type=pdf
R is the radius of a cycloid, and theta the angle of rotation of the disk.
The parametric equations, for level, or nonlevel A and B, are:
x = R * (theta - sin(theta))
y = (-1) * R * (1 - cos(theta)) {The negative 1 is applied so that the y axis increases with height.}
For level A and B, R = L / (2*PI)
Travel time on the cycloid is equal to the SquareRoot(2*PI*L / g)
g = 9.8 meters per second per second, which is earth gravity.
This particular cycloid can be plotted in MoI relatively easily, e.g. with FXGraph, or a simple script.
If your design starts with A and B at different levels, a mathematical solver will be needed in order to solve for the correct values of R and theta for the cycloid...
I do not currently know how to program a solver. There are math software programs which do solving...
- Brian (past bedtime)
