Background Image Rotate
9050.2 In reply to 9050.1
Hi propmaster, while you are in the View > Image command you can use the Align option to do that. That allows you position and scale a background image from one reference line in the image to a target reference line in the model.
For your case before doing the Align set up 2 lines of the same length with one rotated by your desired angle and then snap on to the ends of those lines while doing the image align.
