Background Image Rotate
9050.1
Hi folks!
I'm wondering if there's a way to set the degrees rotated in image mode. Check out the attached image.
What I want to do is rotate the image so that the grip of the rifle is vertical. I know the exact number of degrees it needs to be rotated, but I can't type a value into the 'Angle' field. And I haven't yet been able to do it manually after many attempts.
Is there a nifty trick that I've overlooked, or maybe a script I could install?
