Constant Viewport refresh?
9039.4 In reply to 9039.3
Hi Fubax, well I really don't recommend it but you could try inserting a some script like this inside of CommandBar.htm :
		<script>
			var g_intervalID = null;
			function constantRedrawTimerFunc()
				moi.ui.redrawViewports();
			function startConstantRedraw()
				if ( !g_intervalID )
					g_intervalID = window.setInterval( constantRedrawTimerFunc, 300 ); // call timerfunc every 300 ms.
			function stopConstantRedraw()
				if ( g_intervalID )
					window.clearInterval( g_intervalID );
		</script>
Then set up 2 shortcut keys with:
script: moi.ui.commandBar.startConstantRedraw();
script: moi.ui.commandBar.stopConstantRedraw();
The call to moi.ui.redrawViewports(); will not immediately draw the viewports, it will mark them as needing an update and they'll get redrawn when the message queue is next emptied.
