Rebuild curve variation
9031.2 In reply to 9031.1
Hi Fabien, I'm not aware of anything that would do that. That's a significantly different type of result than the existing one so I doubt it would be feasible just by a modification to that existing script.
In your desired result, how is the spacing between points determined, are you looking for all the line segments to be of equal length? And you want to choose the number of lines?
What kind of result would you expect on that curve if you said make 3 lines for example?
