got a problem fill / close an area....
902.2 In reply to 902.1
Hi Lish, since that is a planar cut, you can use Construct / Planar to build a surface there and then join the pieces together.
But in MoI, the Planar command needs to have a fully closed outline.
So beginning with this model:
Draw a line snapped between these 2 ends:
Now select the line, and the edge of the surface to form a closed loop, then run Construct / Planar to build this:
You can now delete that line segment. Then select the 2 surfaces and use Edit / Join to glue them together into one single object.
It is a lot harder to fill non-planar holes, MoI does not have the full equivalent of the SolidWorks Fill command yet to fill more freeform areas, it is something that I do want to add in the future though.
