MoI3D to CNC router ...
8998.14 In reply to 8998.13
Hi Wimverbe,
First - thank you very much for your prompt reply! ... I appreciate this ;-)
And then - seeing the screendumps in your post I looked a bit more into this this morning and found out that the reason why I can't export DXF from within MoI is because I am using V2. Apparently DXF export was added to MoI in V3. And for some reason the other solutions I tried for converting the file to DXF (online internet conversion & other CAD programs) didn't work at least from a quick glance ...
This is to say that since I have for a long time now been considering upgrading to V3 I decided that this was the time to do so. Thus I have now bought an upgrade and with inspiration from your guidance it took less than five minutes to make the DXF export and correctly import it into Estlcam. Quite a relief ..
So Wimverbe - thanks again for your help & wishing you a pleasant day ;-)
Jesper
