MOI3D on Surface Pro 4 tablet is a little challenging
8985.1
Hello,
Absolutely in love with MOI3d on my desktop computer - on the surface 4 Tablet I am running into some issues. Maybe someone has some insight regarding how to work around it or perhaps there is something i'm overlooking.
The Surface 4 pro screen is HiDPI so points, lines and other geometry are hairline small. It makes connecting, even snapping to points a massive challenge. I have to get within fractions of a mm to get points to snap. Selecting edges when the area that they will register touch input with the pen can also be exhausting. Is there a way to force a larger scaling in points and lines? My desktop machines are 4k and 5K - which is higher resolution than the surface 4 Pro but the lines and points are still a reasonable size. This is probably due to some configuration on the Surface 4 Pro. Maybe someone has encountered this and figured out a solution.
Also lasty - Love the support for multi touch but is there a way to disable rotation on non 3D - orthographic views? It sometimes makes lining up elements hard when everything gets rotated on top/bottom, left/right, front/back views.
Thank you!
Jordan Wright,
www.insidejobfilms.com
