Problem with exporting from MOI 4.0 to Adobe Illustrator
8980.2 In reply to 8980.1
Hi Petr, are you using the "Preserve Units" option when you're exporting? If so then it's possible that your objects are some distance away from the visible page in Illustrator. With "Preserve Units" enabled, currently MoI will map its 0,0,0 world origin point to the 0,0 Illustrator origin which is in the lower left corner of the page in AI. So you would want to make sure your objects are contained within a page sized rectangle area starting at 0,0,0 in MoI if you're using that option.
If that's not what you were running into can you please post your AI file here or send it to me at moi@moi3d.com through e-mail if you want to keep it private?
