Strange issue with dimensions display, particularly after extrude.
8954.1
Sorry Michael, I feel like every few years I bug you about viewport dimensions :(. I am doing some small/medium parts in mm (~2 meter max bounds) and have noticed that when I extrude them the dimensions are changing ever so slightly in the viewport.
I am starting with a relative simple polygon closed curve with a bounding box of 450.00000mm x 842.00000mm, but once I extrude it by 80mm it is becoming a solid with displayed bounds of 449.99997 x 79.99999 x 842.00000. If I click to edit the size I am presented with 450.00000 x 80.00000 x 842.00000 as my starting values, and if I draw a line across the part the line has a length of 450.00000.
I am therefor assuming that this is a display error, is there anything I can do to fix it?
FDP
